Discuss Smoke Alarm Certification in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
M
mercanlandy
Hi, when you do a complete/full rewire on a domestic property which must have smoke and heat alarms installed is it a requirement of BS 7671 that a certificate must be completed for the new smoke and heat alarms as well as the new installation certificate. Typical properties are 2 up 2 down terrace houses. I have read in the NICEIC test and inspection book that you have to and am just checking as I am costing work and wish to factor in this element of the job if it is mandatory.
Regards
SC
Would certainly have thought so. Worked on a partial new build recently and Building Control required smoke alarm certification. The decibel meters aren't half as expensive as you would think though!
I'm not sure I understand this fully. I've just done a full new installation, including 2 smoke alarms and 1 heat alarm in the kitchen. Are you saying that I have to fill out a BS5839 cert. as well as a 17th ed. Installation cert? No-one's ever mentioned that.
Reply to Smoke Alarm Certification in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
  • Locked
Required asap for price work. No of Workers: 2 Location: Brighton & Hove Description of Work: Installation of 230v operated, radio linked smoke...
I know this has been brought up before but as a QS for a housing association ,i have been asked my opinion on interpretation of the regulations...
Hopefully an easy one without much debate but I've just had spoke to someone who has had an electrician go to his rental property and say it needs...
Not come across this before, so would like some help, please. I went to install smokes and heat alarm (to new Scottish regs) in a fairly modern...
