Discuss Smoke Alarm in the DIY Electrical Advice area at ElectriciansForums.net
JackiH
Hi everyone, I apologise if this is a stupid question but I need help. Ok so yesterday I burnt the toast lol and the smoke alarm went on as it should do, my neighbour was here and said to just tap the Hush button and it will go off, so i did, and it did, for 30 seconds or so, and since then it keeps bleeping every 30 seconds or so and will not stop. I have tried to reset it but it still is the same. Any help appreciated please.
JH
Backup battery low.
Although burnt toast suggests that an ionisation detector has incorrectly been fitted either inside or directly outside the kitchen. They may be cheaper, but they're not appropriate for many areas.
Ah ok thank you I will look into that.
if it's in the kitchen it should be replaced with a heat detector. if close to kitchen, an optical sensor is preferable.
Hi, the smoke alarm is in the hallway downstairs and another one on upstairs landing. But the hallway and kitchen are very small and so very near each other. The landlord has also installed the carbon monoxide alarms in the kitchen and one upstairs, plus an air conditioner in the kitchen, which wasn't on yesterday, the previous tenant switched it off and the switch is right up by the ceiling lol but I managed to climb up there now, so that we can use it by using the pull cord. I think I will have to see if one of my neighbours can bring some steps so we can check out the battery in the smoke alarm at least. I really appreciate all the replies, thank you.
Reply to Smoke Alarm in the DIY Electrical Advice area at ElectriciansForums.net
Hi all, Requesting your help please! I know this is an old system but has been working amazingly for 7 years! I had an engineer out who done a...
Hi everyone, I need help installing a Lorex smart doorbell. I have tried to install a doorbell transformer several times to no avail. The first...
Can someone please guide me on this? I have virtually no experience of home alarm systems. The client has an alarm which had been fitted to her...
Hey everyone, here's my imaginary problem, let's say I have 2 light bulbs, both of them take energy from the same source, however, 1 of them has a...
Hi, just wondering if anyone could help me. I’ve just installed a texecom Veritas alarm in my garage at home and can’t seem to get rid of the...
