B
bijly
Hello,
I'm getting a loft conversion done and there is a requirement for mains-powered smoke detectors in all rooms. the electrician is part p and will be installing new small cu.
The new smoke detectors will be using existing wiring which is using old type wire fuse box ( i've replaced some for the fuse switches ). so my understanding is they will use existing wiring off the lights and so my question is will this be ok for the regulation/ part p or am i looking at more work required?
thanks in advance for your responses.
