Discuss Smoke and heat alarm issue in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
R
Rosco22
Hi all
Ended up at yet another partly done electrical job trying to figure out whats been done and what hasn't. I noticed the spark has not included a new circuit for smoke alarms as its a refurb + extension on a flat and thought ideally one should have been installed. Can I just take a local supply from a light and install radio link bases? As the place is nearly finished.
Advice appreciated
I never install new circuit for domestic smokes.
How many times do you see houses with batteries removed and MCB turned off????
Saw several badly burned/dead people in my other job due to this.
NEVER NEVER install domestic smokes on their own circuit!
Good shout CBw my mate who's a good spark puts both smokes on the same circuit I've always used the lighting circuit so your comments are interesting and I think your right can't have smokes isolated if there on lighting circuitcircuit
should be fine when i rewireing for the council they did want the smoke/carbon/heat on a separate circuit the tennent could just just turn it of i used to just take it in to JB as the space in the alarms can be tight sometimes with 2 3 core T+E going in them
I know this is being pedantic but;
Table 52.3
If your lighting circuit is in 1mm then, strictly speaking, you can't use it to power the detectors.
Laurie
Reply to Smoke and heat alarm issue in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I am an electrical labourer currently doing my own research on Alarms to self-educate as much as I can. I would like to state the general rules I...
I know this has been brought up before but as a QS for a housing association ,i have been asked my opinion on interpretation of the regulations...
Not come across this before, so would like some help, please. I went to install smokes and heat alarm (to new Scottish regs) in a fairly modern...
Hi everyone Ive just had an electrical condition report conducted on a mixed-use property, and I am extremely surprised that after the last report...
