M
MGB_Roadster
My house is about seven years old, it has one heat detector (Ei144) and three smoke detectors (Ei141). They're marked "replace by March/May 2018".
Last week the heat detector started chirping, about once a minute, as if the battery was running down. I did a push test and it worked o.k.. I put a new battery in anyway, but it still kept on chirping, so I bought a new detector and fitted it on Monday (sliding it onto the original base). Everything was working hunky dory.
About midnight on Wednesday I heard a chirping from downstairs. It turned out to be one of the smoke detectors. I didn't want to do any testing at that time so I just took the unit off the base, removed the battery and turned the power back on.
Going back to bed there was ANOTHER chirp. This turned out to be a second smoke detector.
It seems a bit far fetched that after seven years without problems three of the four units should fail within a week, the last two within half an hour of each other. I spoke to an electrician who thought it might be a fault in the link cable. He suggested I test this by pressing the Test button on one unit and getting Mrs Roadster to run round and check that all the others were sounding.
All the units sound when one of the test buttons is pressed and the mains is off. When the mains is on all show a green power light, and two of the smoke detectors chirp intermittently.
Any suggestions what might be causing this?
