Discuss So, Do Electricians Have Top Of The Range Consumer Units And RCBO's in the UK Electrical Forum area at ElectriciansForums.net
Heck no ,
still have the plastic proteus split load board that came with our current house
haven’t touched it since we moved in 5 years ago , other than to reset the rcd a few times when for some reason the new over trips it on occasion
house was rewired c. 1990 (before my time here) all the VIR cables replaced and new accessories. being Polish, they had no concept of RFCs so 2 socket radials went into the same 30A fuse. in the old DB from 1956. during the process of adding more sockets, downlights, etc., i have put the radials on separate 20A MCBs, inside a plastic BG dual RCD board mounted sideeways the save demolishing a supporting wall ( was before 2018 ), with the garage sub fed from a non-RCD MCB as we have 3 freezers in there.
Why did you bring the earth cable out the trunking via a stuffing gland ...?
couodnt you have simply taken into the board with the other cables ...?
Water bond from the far end of the house, I just like having a MET outside the DB, adds a little colour to an otherwise drab part of the house.
Reply to So, Do Electricians Have Top Of The Range Consumer Units And RCBO's in the UK Electrical Forum area at ElectriciansForums.net
Hi got a 8 panel solar system on bungalow, changing the board to 18th edition spd board Solar feed is chased into wall so will this need a type B...
Evening all . Just a quick question what do you guys typically charge for an rcbo spd consumer unit change 14 way . 10/11 rcbos few spare ways ...
I wondered if it is OK to have 2 x Main Switches in the same consumer unit. One feeding the RCBOs in the House and one feeding the CU in a garage...
I am planning to go semi off grid with a victron and battery system. The system will be installed in an out building about 20 meters away from...
Hello all.. I'm quoting for some work and would like change the type AC RCBO to a type A. Consumer unit is a castlec which I have not come...
