A
Discuss Socket choice and position for wood panelling in the Australia area at ElectriciansForums.net
depends how deep the lip is. might have a problem getting the plugs inI think for the best look, flush butted up to the lip at 900mm
just a thought... could you come from socket/s on the back side of the walls and drill through?,
Flush butted up to the lip would definitely cause a problem with getting plugs in, and any higher may mean some short flexes won't stretch.I think for the best look, flush butted up to the lip at 900mm
Good thought, but I also can't come through from next door as only one wall is not exterior or adjoining, and that's a solid wall.just a thought... could you come from socket/s on the back side of the walls and drill through?,
This is probably what would look neatest.i would, with the customer's agreement, fi in the panels . have come across this situation where there was just enough clearance behind the panels to fit a 25mm K/O box. and flush fit. ( might have to chip into the plaster in your case.) or, again after consulting client, you could mount above the panelling. if cables come from above, means you don't have to touch the panelling, sockets still below 1200mm.
Thanks for the replies
What height would you fit them at?
Flush with the 300mm high detail on the panel, or maybe at 350mm or 400mm?
Reply to Socket choice and position for wood panelling in the Australia area at ElectriciansForums.net
