Discuss Socket distance from floor in the UK Electrical Forum area at ElectriciansForums.net
Hi
I am building an annex in my rear garden.
Unfortunately the electrician has not fitted the sockets at a distance 450mm from the floor.
As I understand the 450mm distance is for new builds would an annex constitute a new build.
Please advise
Hi
Please advise
See the building inspector overseeing the project and get their input.
Is that similar to the rest of the house.
Fine though as it is as an annex isn't classed as a new build.
What has he set height of light switches at, existing or somewhere near new build heights of 1200mm max ffl.
I’d have gone with the same heights as rest of the house so they don’t look out of place.
Unless they were ridiculously low and could cause damage to accessories being plugged in.
As above, the socket 450mm height (and lower switch height) only applies to new build properties. These heights are a requirement for disabled access as mandated in BR Part M.
Thus building regulations document also details a whole raft of other requirements including ramped access, wide doorways on downstairs WC for wheelchair access etc etc. I’ll bet your annex does not include any of these features because they are not needed.
socketsshould be fitted at whatever heightthat you, as the customer, wants them ( providing that they are not so low as to damage appliance flexes).
Did you not raise this at the time when you saw the boxes being put in? Is it important to you the height?
To answer your question, assuming this is a permitted development, it must comply with building regs. Has the socket circuit been extended or is it a new circuit? If new then it would require notification to the council. Was this done? Is a building inspector overseeing it to sign it off?
Yes not needed so just to confirm a new build is a new house, flat etc
[automerge]1593556394[/automerge]
Just to confirm a new build is a complete build house, flat etc. An annex still constitutes part of the house so it’s not classed as a new build is this correct.
note the Annex is detached from the main house as it’s built at the back of the garden
Reply to Socket distance from floor in the UK Electrical Forum area at ElectriciansForums.net
Hi, after some discussion with electricians, does removing a 16A or 32A socket constitute safe isolation? I understand that removing the socket...
Hi all. Looking to buy a house where the rear of the house is the rear boundary, onto council owned land (a footpath). I want to build a new...
Hi everyone, I am a removal man and I build office furniture. The company that I work for has based me at one of there clients buildings which...
Hi Guys Got Client asking me to fit these floors sockets…. Got my doubts, looks like cheap piece of tat !! Just sent me photo from what they’ve...
Hi, I'd like to move the existing socket that feeds the boiler down to where I've pencilled in that can be seen on the photo. The socket to the...
