Discuss Socket not working anymore. in the UK Electrical Forum area at ElectriciansForums.net
Just bought an MK FCU. I’ve now safe isolated the circuit. I’ve split it so I have the circuit for the outside light. Which is to the right and then a circuit coming from the top. Old colours are from the socket below and the new colours are from the spurred socket.
Looking at the back of the MK socket it had the supply and load. I am looking at how it was wired previously
Load would be the outside light and the Supply would be the sockets.
Would that be correct?
So the old coloured cables are part of the existing RFC and the new colour is a spur socket from the RFC?
New colours are from the addition socket that is spurred from the FCU. Old colours are from the RFC. As all the sockets downstairs are on a RFC. Which is then has a feed from that socket to the FCU.
Socket on the bottom is on a RFC. Which is in old colours. It then has a spur to the FCU above in old colours. There is then flex for the light in old colours in the FCU. Then the final socket is then spurred from the FCU in new colours.
Good news is the outside light works.
So tried again, bought a new lamp for the outside light. Wired the spur so that the Load Side is the Light and the Supply is the sockets. Tested the socket under the bracket. Still not working with the Socket Tester. Tried the FCU with the new lamp. Nothing.
I then looked at the wiring on the RFC, it seems that one of the live (red) is quite short. It reaches into the socket but barely, so I have got a crimping tool, some blue crimps and some 2.5mm2 T&E. So I am going to try and extend any short cables. Although the socket tester has come back all green lights, showing no faults.
I personally think you should get a spark to check this out to be on the safe side. I'm sure he wouldn't mind going through what he is doing once he knows your a trainee.
So if the light, wired to the new FCU is not working then the problem is going to be before this.
Is your bottom socket functioning ok?
Yes the bottom socket is okay. Tested with a socket tester and it’s all green. TV is plugged in and working.
Edit... Brain fart moment...
So just to recap. The bottom socket is working. This wires to the new FCU which is not working.
Are the wires going from the bottom socket to the FCU ok?
Yes that’s correct. The wiring appears to be okay. No signs of damage. But as mentioned one of the lives although reaches just, is a little short. So I was thinking of maybe adding some blue butt crimps to that and then using some 2.5mm2 twin and earth to extend the cable. Just to see could that be the issue .
The cable length looked ok in the pics you posted up before, but you are there so you will know... :)
If the light to the new FCU isn't working or the socket wired to the FCU, then it seems to suggest its the cable from the bottom socket to the FCU that may be at fault.
Those cables look okay as I say. Would it be okay to do a butt crimp on the live and use the brown from the 2.5 t&e as a new live?
If you need to extend one on the cables then using a butt crimp and descent heatshrink would be one way of doing it.
Someone did post a nice little inline connector (Not Wago) in a past post, that looked good.
Reply to Socket not working anymore. in the UK Electrical Forum area at ElectriciansForums.net
Hi guys, newbie posting! Does the following sound ok... Existing circuit: SOCKET on a ring -> spur to SWITCHED 3A FCU -> SWITCH -> hardwired FAN...
Hi. I'm in the process of getting my qualifications and am taking on some small jobs for family to try and get some experience in. Today I was...
Hi, I swapped a 2 gang switched socket for a 2 gang switchless socket with usb ports downstairs. I switched off all the power to the house by...
Hi, just helping someone out and apologies for the long winded post. Would like install a couple of weatherproof double sockets on the patio. 1...
