Hi, hoping for some help please. I’m not an electrician - just an occasional DIYer.
Replacing an under-counter fridge and the socket has a problem. Tested it with a Kewtech 107 tester. Neutral light flashing amber in bottom left of triangle. Took socket apart (faceplate is a bad fit for backbox). Not wired incorrectly and holding firmly but took them all out anyway and reseated. Still same problem. Can’t see any obvious damage to wiring but whoever put it in did not sheathe the earth cable. Any ideas please? Thanks in advance. Tom
