Discuss Socket spacers? in the UK Electrical Forum area at ElectriciansForums.net
I always put yozzy boxes on now so they can't .i hate tillers sometimes the f up round a socket
Spin one thing I have tried which is quite effective is timber fill for this because it sets absolutely solid within about 60 seconds it is white and gives you a really solid base to screw back toIs the isolator falling into the hole, or is it that the screws are too short?
Could you use a different make of isolator that is slightly bigger?
Could grouting or filler be used to fill in the hole?
The hole isn't too big, it's just the switch sits too far in as the box is sat really deep due to the tiles.
I was thinking about the extensions lugs as well so may use though. May be able to bulk the gap a bit with some solid filler.
Thanks all
Is that not you in the avatar then Tel?
Reply to Socket spacers? in the UK Electrical Forum area at ElectriciansForums.net
