- Reaction score
- 1
I am changing my oven to a gas only oven and wanted to know if it was sufficient to put a blank plate on the original socket as it is will be close to the oven. Any help much appreciated.
Discuss Socket within 300mm of gas oven in the UK Electrical Forum area at ElectriciansForums.net
There used to be a electric oven with a flex going into a 3 pin plug going into a 13a double socket. The new gas oven doesn’t require an electrical supply so need to remove the socket as it is behind the oven, wanted to know if blanking off the socket would count.Are you meaning there is a cooker isolator with a socket directly above the job area? Or did you mean a normal double socket to one side?
Thanks that would really help, yes that’s what I thought as no appliance would used if it’s blanked off so surely won’t cause a problemAh ok so this is from gas regs point of view.
I thought it was 150mm in the gas regs.
I’m seeing a gassafe chap tomorrow so can ask for chapter and verse on this but to answer your question I’d have thought that putting wago connectors on the wires and a blanking plate would satisfy everyone, including a future sparks wanting the the joints behind the blanking plate to be maintenance free.
So by removing the current socket and replacing with a blank plate that would be goodOur sparks on site guide says this:
7.4.3 Separation
Separation of gas installation pipework
Gas installation pipes must be spaced:
(a) at least 150 mm away from electricity supply equipment, such as metering
equipment, main service cut-outs or supplier
(main) isolation switches and
distribution boards or consumer units;
(b) at least 25 mm away from electrical switches, sockets and electricity supply
and distribution cables. The installation pipework shall not be positioned in a
manner that prevents the operation of any electrical accessory, i.e. a switch or
socket outlet.
The cited distances are quoted within BS 6891:2015. Specification for the installation
and maintenance of low pressure gas installation pipe work
Reply to Socket within 300mm of gas oven in the UK Electrical Forum area at ElectriciansForums.net
