Discuss Sockets in Loft in the Australia area at ElectriciansForums.net
P
paddy1515
Hi
I have a enquiry about installing sockets, a friend has asked me if it is possible to run 2 x double sockets in his loft of a 13A fuse spare that is all ready feeding his boiler. Is this possible if not what is the best solution
Cheers
Dave
Not a good idea, the boiler/immersion needs to be on its own circuit and rcd protected.
Someone will give you some more info soon.
Si.
Is the spur on its own circuit ??? Does it feed boiler or immersion ??
If feeding immersion not recommended if the immersion is still in use.If it feeds boiler you could run a couple of sockets because the boiler is not much load.Also depends on what the sockets are to be used for ??
I don't think you can take it off the lighting circuit. Bear in mind that a usual lighting circuit is only on 1mm cable and protected by 5/6amp fuse/MCB. A socket requires 2.5mm and 30/32amp protection. Also depending on age of the house the lighting circuit is not necesseraly on RCD protection which a socket should be.
Because a socket is able to take many different items, you can never really estimate what load will be put on it so adding it to your boiler could cause problems in the future.
Is it not possible to take a feed up from an existing socket on the first floor?
The lighting circuit idea puzzled me as well. :confused:
I thought the only way to add sockets is either on a new circuit or via spurs. Is this corrent?
I take it 'proper pants' is a name bestowed upon you from your abilities as a tradesman :D
I think "proper pants" is taking the pi** because the guy who asked the question is obviously not a spark and should,nt be attempting this kind of work
i think you're guess is the one mister assured.
although one can't be too sure when he's only made 5 posts for us to judge his sense of humour
i think his use of a 13A fuse spare (not spur) was a bit of a tell tale there
Well I guess I fell for his sarcasm, lowest form of..... etc etc
I would be careful what you put on here. Some people may just believe you. Me included!!!!
I think the thing is, there's probably a million and one DIYers who just see a wire and think they can connect to it regardless of insulation, size, use.
And they are the people sitting at home right now with the lights that dim everytime the fridge compressor kicks in:D
well i guess i fell for his sarcasm, lowest form of..... Etc etc
i would be careful what you put on here. Some people may just believe you. Me included!!!!
I think the thing is, there's probably a million and one diyers who just see a wire and think they can connect to it regardless of insulation, size, use.
And they are the people sitting at home right now with the lights that dim everytime the fridge compressor kicks in:d
lets ****in hope so!!!!!!!!!!;)
WOW that question started abit of a rant (sorry)
OK i'm new to this trade and i was only wondering if you can run the two sockets of the fused spur because it would be a pain in the butt running them from the up stairs ring main, I can't find anything that says you can't do in the regs.
I know u def can't run the sockets from a lighting circuit thats just bloodly stupid if you ask me.
The fused spur only feeds the combi boiler on its own circuit
13A fused spur may be run as a spur from an existing socket on a ring circuit. As far as the regs go you can supply fixed equipment and sockets from it. You can't overload the spur as it has a 13A fuse in it. Obviously if you put a double 13 socket on it and the boiler supply....thats a potential 31 Amps in my book, (13+13+5 for the boiler) so the potential is there to overload and pop the fuse.
Sockets off the lighting circuit? Mmmm....interesting....not
Hope this helps
Randyrat
Answer is , yes you can run as many sockets off a f/s as you like as long as the spur for the boiler come off the ring and not off a previously spured skt..
What you could do is - replace the switched f/s with a un switched 13a fuse spare , then from the load side of the spur supply another sw fuse spur 5-amp for the boiler
and also supply as many skts as you like from the load side of the unswitched 13a f/s
as the 13a fuse is the protection from overload
Read the 17th editon - refer to dedicated circuits - they SHOULD be dedicated - rather than the 16th edition MUST be dedicated... - Now the electrician can make the decision on these circuits. -----I wouldnt run want2 run 2DS off it but would allow light use such as boiler pumps - even shower pumps now. Must insert here that theres usually a better (may not be quicker )way than 'tapping' into a dedicated circuit most of the time. If no ring main in loft id run from 1st floor a cable/s into loft along a safe zone - a spur off a socket in a bedroom maybe.... -
Reply to Sockets in Loft in the Australia area at ElectriciansForums.net
Hi, I'd like to move the existing socket that feeds the boiler down to where I've pencilled in that can be seen on the photo. The socket to the...
I'm sure this has been asked before, but I just want to confirm: Currently I have a spur leaving a socket in the bedroom, into a 13A Switched...
Hi fitting a a couple loft sockets on a radial circuit. I only have 2.5mm cable and really don’t want to buy a reel 4mm2 is it ok to use on 32A...
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
