E
elementps
Ideally would like someone to take the whole lot but let me know if you want individual bits. Can be collected from Berkshire or will post if costs covered.
Have pictures of everything so if you need more info, just let me know. Will accept any reasonable offers.
Pair of Irwin Quick Grips, setting 0-160mm.
18 x Halolite GU10 Reflector, 50W Halogen, 36 degrees.
6 x Phillips GU10 Reflector, 50W Halogen, 40 degrees.
35 x JCC GU10, 50W Halogen, 40 degrees.
2 x MK IP66 Switched Fused Connection Unit, Grey
2 x Metal clad, MK 13A 2 Gang DP switched socket
1 x Metal clad, MK 13A DP switched connection unit
Accessories all brushed steel (dark), black inserts, Volex:
2 x 45A Cooker switch + 13A socket with neons.
2 x 13A DP switched socket 2 gang.
7 x Halolite 12V MR16, fire rated downlight, polished chrome, lamp included.
7 x Halolite 20-60W/VA Transformer, Dimmable.
3 x Exterior Spike/Wall Spotlight, GU10, IP67, Black
1 x Kinightsbridge GU10 Spike Spotlight, IP65, Black
Also for sale, Rubi Wet Tile cutter, Erabauer electric sander.
