Discuss Solar help electrical in the UK Electrical Forum area at ElectriciansForums.net
noodi3
so lets say i have a 12v solar panel and it puts out 5amps current =60w. If all my accessories connected are 5v and drawing 5a does that mean im only really drawing 25w of power outof my system? If so does that mean i can get 12a at 5v from my panel?.
This thing wont let me post my thread unless i write more characters
Ill stsrt again.
If i have a 18.2v system with a 6.04a output
When i use the regular to bring it down to 12v
So lets say im charging my car battery at 14v
Does this mean because im only using 14v out of the 18.2v that im able to achieve a higher current output of 7.8a@14v instead of 6a@18v
18.2v 6.02a=110w
14v 7.8a= 110w
Get me?
It depends on what you mean by achieve?
Yes you'll have 14v and 7.8amps available but then you'll have losses in the voltage regulator to remove from that, and loss of power in cables as well.
What are you trying do? Might be better to start from there.
Firstly I presume you mean transformer by the term regulator?
If you had a 230w 230v lamp that was supplied by 230v then it would draw 1a. Similarly, a 230w 12v lamp would draw somewhere around 19.17a.
But the 230v lamp will hardly light at all at 12v and similarly the 12v lamp will blow pretty much straight away at 230v.
You cannot connect things to a device unless they are rated at the same voltage as that device.
I think you need to a bit of research into electricity and how it works.
Transformer are for AC systems only
Dc system use regulators to change voltages.
Both have there own inherent inefficiencies
Lamps don't work like as you've got reistances involved to achieve those voltage drops.
So a 230watt lamp at 230 volt would have a fixed resistance of 230 ohms
While a 230 watt lamp as 12v would have a resistance of 12ohms(aprx + simplification for the sake of maths)
So now if you feed 12v on it the 230 volt lamp it's resistance is still 230 ohms(ignoreing heating effects so using ohms law v=I*R bit to arrangements
I=V/R = 12V/230 = 0.05A
your not drawing 19amp but actually 0.05amps or 0.6watts, hence why it doesn't light up as bright.
Your best bet is to let us what your trying to do so proper and ice can be given
Ok thanks..
I have a 110w solar panel on my car roof.
Please see attached picture they are the specs
So all i really want to know is will i get
7.8a@14v instead of the [email protected]. Because i have the regulator dropping the voltage will the current be increased
Its charges my battery and i run my fridge and charge my phone, GPS and other 5v stuff through the car that has a regulator in the cord to bring it down to 5v
Reply to Solar help electrical in the UK Electrical Forum area at ElectriciansForums.net
Hi, firstly appologies if my terminology is wrong but I know very little about electrics and have no idea why this is happening - I have 2...
Hi, I have a Solar Iboost and I understand that when I export electricity, it gets directed to the hot water tank. Is it supposed to be directly...
Hi all. We have had 7x 400w solar panels for a number of years now on our roof which is se/nw facing end terrace. 4 on se side 3 on nw side...
We have got some other sections of the forum that I thought might be useful to you guys! They are for all countries but we have new tags that you...
