Discuss "Solar into Grid Tied Inverters" is going to die off? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
My apologies for this duplicate thread, this thread didnt at first show up, and it made me log back in....
This is what i mean...
GTI's have got serious problems up ahead !!!
If people want there own solar generation. Then pretty soon, they are going to have to "island" their household mains from the grid, and just use a standard Non grid tied inverter from the panels to supply their household...
This is obvious, do you not agree? GTI's are no good when too many people have them, because they "pump" the mains voltage up, and GTI's stop working when mains goes above 253VAC.
Indeed, and it's even more of a problem for us over here in the land of the great death orb in the sky.
I think long-term integration of domestic PV is going to require inverters that can be controlled in their back-feeding and/or intelligent transmission and transformation grids that can turn down their tappings to allow for more infeed.
Thanks, i must admit i doubt the authorites will choose to adjust the national grid to make way for solar. I think that people who have solar will just have to "island" that bit of the mains in their house, which connects to their solar system. ("island" as in disconnect that bit from the national grid). Would you agree?
I doubt they'll need to disconnect entirely, but the days of loading up your roof with panels and getting paid to feed into the grid are numbered. Eventually most homes will be limited to supplying their own needs and maybe a little to their neighbourhood, depending on the local voltage.
Reply to "Solar into Grid Tied Inverters" is going to die off? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi all, My 3 month old grid tie inverter has tripped on 3 occasions at startup. Have read plenty of threads here about similar issues but unclear...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
Hello All Can I say to start with I am not an electrician but used to be a heating engineer (yes I can hear the groans). I have wired the...
14K
Hope this all makes as much sense as i can make of it and my "problem" can get sorted via some guru on here... Just a quick background on myself...
I'm in a questions asking mood tonight. I briefely looked at a job today and I need to recommend a board change but need to justify it. Firstly...
