Discuss Solar panel rating measuring in the Electrical Engineering Chat area at ElectriciansForums.net
Agree, I knew a couple of people who had met this issue. How could you sort this out? is there a measurement tool that can tell you what is the exact capacity?Be aware that the specifications of some of the cheaper panels are often exaggerated!
I think Current measurements should be measured in amps, not milliamps. Milliamps are used to measure the power consumption of small electronic devices like flashlights or calculators, and discharge rates of batteries in gadgets shouldn't be taken too seriously since they'll often change significantly from day to day and even hour to hour.
Reply to Solar panel rating measuring in the Electrical Engineering Chat area at ElectriciansForums.net
