Discuss solar pv in cyprus in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
G
Grumpy
no i don't know why this forum doesn't support my shift key. however i'll persevere.
i have a friend in cyprus who would like to run his swimming pool pumps off solar pv. does anyone on here know anything about cyprus eg is there the equivalent of a fit qestion mark. unlikely i think. what about the only elctricity supplier, do they permit grid tied question mark. alternatively, do you have any suggestions where i might source this information and info on solar irradiance and the like. might be a rather tasty install exclaimation mark. thanks in advance.
Why would he run the pool off solar PV? Unless he is proposing heat pumps, he'd be better off with Solar Thermal, simpler, cheaper, or try the Thermodynamic Solar Panels, makes much more sense - "heat to heat" not "light to leccy to heat to heat"
Reply to solar pv in cyprus in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Greetings, everyone, After dedicating over a month to researching Solar PV systems, I'm nearly ready to make a decision. I owe my progress to...
Good Morning All! Always appreciate reading the great ideas and conversations in the forums, and now actually have a chance to ask a question...
Hi, I've got both a solar pv and an ashp system. The solar system also has 2 batteries and it's configured to fill the batteries first and then...
Hi, Similar'ish question to my other thread but little more info now so a different approach but sorry if duplication. UK, single phase. Just had...
HI Folks. This is my first post so apologies if it's in the wrong location. I recently installed a 3kw Solar system with an iboost diverter...
5K
