Discuss Solar River 4000TL-D, can you change the scale on the output graphs? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
U
Unregistered
Customer has this inverter with 16 panels. Happy with system but when looking at the historical data on the inverter the annual history has a scale such that in November to March there's hardly anything to show and even in a sunny April, with about 500Kw it's only going to be a small block on the histogram. Ideally I'd like the scale to go up to about a megawatt but it's scaled up to about 2mW. Anyway of changing it?
Reply to Solar River 4000TL-D, can you change the scale on the output graphs? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hello All, I'm seeking some advice about a solar PV system we had installed in November 2014 please. After 18 months, we seem to be consistently...
6K
crossplot
C
I just had a 4kW system installed. It uses the Samil Solarriver 4000TL-D inverter which has 2 DC inputs. There are 2 strings of 8 panels, each...
7K
M
Hi I had a solar panel system fitted 22 Feb 2012. The system includes a 15 panel sharp 245 array split into 2 strings of 9 and 6 running into a...
11K
J
Hi All, Apologies for the consumer-oriented questions, but this seems to be one of the best forums on the web for discussing PV. I’m looking at...
10K
finewine
F
hi i hope you are well. i have an Eversolar TL4000 GB inverter - 1)id like to hook it up to my pc so i can get a graph of output per day - i...
6K
