Discuss Solar thermal in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Need some advice regarding a solar thermal system. To remove existing cylinder is going to be a nightmare, small cupboard and pipes covering the cupboard. So I am thinking of installing separate cylinder and piping the hot water from the solar cylinder into the bottom of the existing cylinder. Any thoughts.
Sorry Jason, I know the answer above did not help, it did make me smile though.
I can not help you at all on this one though, but I am sure someone will.
Even at 8 panels they will get more benefit than thermal
anyway if you have your,mcs solar thermal,unvented hot water, and oil registrations you can do what your looking to do.
I am thinking of installing heat pump cylinder with solar thermal. That way he will be ready for heat pump system later on. What's your views on the pellet prices in the next few years, will they be expensive ?
Going back to op I think there can be problems with the legionla disinfection as the first cylinder fed via solar could be sat at ideal temp, make lots of infested water and could run right through second cylinder. Chage cylinder for thermal store over comes lots of issues! Gledhill do some good ones. No discharge pipe work, not a rocket waiting to go through the roof and no need to protect against legionla as its and instantaneous water heater? Hope this helps. Aj
Get him to have biomass
Biomass, you're still in the hands of a 3rd party fuel provider, at the levels the Governements wants to promote Biomass we'll be a net importer of Biomass fuel. - Who control's the price of fuel and the costs of your heating then ???
vented or unvented?
could be worth considering a solartwin system if it's vented, now being made and sold by discrete heat in Manchester at reasonable trade prices, and would mean no need to replace the tank, just plumb in to the cold and hot water pipes from the tank or even near the header in the loft.
Reply to Solar thermal in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
I found myself needing to do some emergency plumbing at home this evening. I've got a small guest flat on my property which has been empty for...
My best mate has been medically retired from the prison service at the young age of 52 and has time on his hands :D He's looking at a 'plug in'...
Can I add solar panels to an existing system without jeopardising my feed in tariff? I have a 3.8kw system but was thinking of adding a few more...
Hello fellow professionals, I'm currently facing a challenging scenario that involves the integration of solar photovoltaic (PV) systems on roofs...
