Discuss Solder Joints in the UK Electrical Forum area at ElectriciansForums.net
SKY
Following on from the recent crimping thread.
What is the best method for solder joining 1.5 and 2.5mm conductors?
Apart from the solder and soldering what other tools or consumables are needed?
Thanks All
I suspect the consensus will be you don't want to do this, but if you do anyway:
1. Make sure the soldering iron is up to the job - e.g. it can deliver enough heat quickly enough (I'd suggest a temperature controlled iron with separate power supply, or Metcal thermostatic bit type - not one of the cheap "toys" you see in hobby electronics shops).
2. Watch out for the insulation melting/peeling back as you solder - and you'll need some sleeving such as heatshrink.
Me Dad had a copper bolt filed to a wedge shape fixed to a length of steel rod with a wooden file handle stuck on the end ..... and a gas ring & tin of flux ........ worked perfectly every time.
Stating the obvious a wee bit here but a steady set of hands usually comes of use.
I have never soldered anything other than low voltage joints myself, i too believe soldering is only ever associated with electronics rather than mainstream electrical circuits.
I have a very similar tool, (not a bolt, a proper lump of copper) made as part of my college course in,,,,1968.
And we used to used soldered lugs on cable and hammers and rawlplug tools and water levels and thread the end of plain rod for hanging lighting trunking non of this allthread stuff.
what you mean, remember. i still use mine. made in college, 1967. have to use a blowlamp on it now though, as we have installed central heating. got no bloody fire now.
Fit physio with VERY manipulative hands. She was brilliant for my shoulder joint, among other things..
we generally put shoulder joints in the oven. lamb or pork, not fussy.
Weak-back ferules, tin-mans solder, resin (amber) flux, gas torch and a mate you can trust.
Oh sorry it’s 2.5. 100W iron, cored solder and heat shrink.
To solder 2.5 mm copper you need a 250W soldering Iron, melting insulation, dry joint, shaky hands, no, seriously I wouldn't do it.
250 watt iron? what a crock... A decent 45 watt weller wil solder 10mm with NO problem at all.
Do you think all the intenal wiring in say a washing machine is crimped? Think again ... sodered joint in copper cables are absolutly fine as long as you know what you are doing..
hands are steady as a rock after a few pints,
Reply to Solder Joints in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Hope this thread is still going. I had to cut my stereo antenna cable, so need to reconnect with another cable. I am unsure as the best...
I disassembled a Christmas light projector to try and identify the cause of why the images from the projector weren't moving at all, when they...
I've always disliked needing to wrangle three 2.5mm T&Es into one 13A socket. The three solid cores rarely sit cleanly, and there's always the...
5K
Good morning all, I am currently working on a House in Multiple Occupation (HMO) consisting of 10 flats, with three parking spots equipped with...
Wanting to add 2 strips of led lights down each side of underneath of the stairs, I have a socket I can spur off, into a fused switch, been...
