Hi All,
Main issue is as per title: inverter is stuck in Off-Grid mode. I used Self Use over the summer, which worked well, priority PV order Load > Battery > Grid. Now the UK has moved into pseudo-monsoon season, I'm only generating 1kWh/day, so I shifted my loads to off-peak grid hours. This includes direct consumption (appliences that heat water). There's a useable 9kWh of PV battery and I set charge and discharge time windows under 'Time of Use'. Contrary to the manual, all 24h must be covered and "Optimal Income" = Run to apply. Charging off-peak worked well, but the Inverter then proceeded to empty the batteries to the grid immidiately it was allowed (pic). To halt the energy dump and run the house over with my purchased kWh, I set the inverter to Off-Grid. But my house loads are hooked up to grid, so I can't disconnect the grid and run the house.
The inverter response is to discharge batteries at <100W only, use the 1kW PV to recharge the next day, and effectively, the house runs using grid power as if no PV is there (pic). I have reverted all settings to Self-Use as per summer: no time windows, no charge from grid allowed, "Optimal Income"=Stop (pic). Full reboot with all power removed for an hour: PV, Battery, grid. Still it behaves as above and reports 'Off Grid' as the mode (pic).
Any suggestions folks? Manual attached including my highlights and text box notes.
Thanks in advance for your time and help.
Mike G
Mike G
