- Reaction score
- 16,960
Hope you can understand this... i really should have taken photos...
OK, bedroom lightswitch. Don't know if its neutral loop at switch, or at ceiling rose... but shouldn't matter.
A joiner has made some built in wardrobes, where the end panel is now coming out from the wall between the doorway and the switch... So the switch is now inside the wardrobe.
Should be a simple enough job to extend the cables at the switch box, and fit the switch along the wardrobe end panel...
The question is how do i make it look good from inside the wardrobe.
I can cut a box sized hole in the end panel, and fit a 12mm deep box, but its going to be seen from inside.
Very low profile 100mm wide trunking if i can get it... or get the joiner to make something to hide the cables?
