- Reaction score
- 118
Discuss someone trying to kill me? in the UK Electrical Forum area at ElectriciansForums.net
why did you bother to test that pile of rubbish
you should have told them too stuff it
My probe testers led me down the garden path today... was working on 480v DC motors and they showed only 80v to earth but on double checking with 2 separate voltage meters that showed the correct L+/E reading it turns out the said probe testers show an incorrect voltage .... leads swapped on it battery ok in meter all things checked but still wrong reading... now strangely leaving the probe on the earth point and going to an AC line it worked fine no issues ..... their sending me a new one and if its the same it could be costly but i wont divulge the make until we know why ...could be just faulty unit lets hope for their sake.
So many defects on that periodic ( still can't get used to the ei... Whatever ) that was just icing on the cakewhy did you bother to test that pile of rubbish
Bleedin' ebay again, eh ?
I've heard of this instance , don't quote me word for word but you need a tester with a true ...rms/or voltage frequency value thingy on it , when working with inverters or you do get dodgy readings
Robbing sods must have a tight budget with a classy instal like that.
Is that a technical term??? :rofl:
A thingy is enshrined in the metric system.
10 thingies = 1 wotsit.
4 packets = a belly-ache.
I had to test the back up generators for them years ago, all on the roof, they were all powered by a 2.8l ford Capri engine running on gas, this was back in 93ishIt's not a good company to work for believe me .... they treat their employees like dog poo.
Reply to someone trying to kill me? in the UK Electrical Forum area at ElectriciansForums.net
