Discuss Something I haven’t seen before in the UK Electrical Forum area at ElectriciansForums.net
It has long been decommissioned..
All controls have been removed.
What voltage did it run at?
It is made from some kind of black cloth with those copper strips along the edges.. Did the black cloth heat up?
They were straight 230v, the black material heats up and is sandwiched between plastic sheet. Back in the day there used to be about 1" of insulation over the top. Not surprisingly the 'fad' didn't last long. Probably one of the worst ideas of all time. Similar mats are still used for vivarium heaters etc.
Yes I also thought that about the plasterboard goving a poor heat transfer..
One of my theories was that it was some sort of mesh system created by a techno geek haha
These were a really bad idea, but the same tech is found in electric blankets, and heating mats for seed germination and home brewing, all of which I've used in the past. They'd probably still be good as heating mats: have you thought about selling them on eBay or Gumtree for greenhouses?
I stayed in a ski chalet in France earlier this year that had ceiling heating installed on the top floor. Vaulted ceiling too.
What an absolutely idiotic idea! What possible benefit would it have had over a very similar underfloor heating system!?
I don’t think selling them would be worth my while as I would have to strip it all out from the loft.. Shame though as it seems a waste just sat there.
The only benefit I could see there is keeping snow off the roof.
Unless there was a means of circulating the warm air.
UFH would seem to be the obvious choice..
Reply to Something I haven’t seen before in the UK Electrical Forum area at ElectriciansForums.net
I’m not working on this… not yet anyway, but can someone tell me why there’s a fuse or a link on the earth here? The green wire is bonded to...
Had to remove a led strip from a bathroom today because it’s getting tiled, now the led strip that was there was low voltage but didn’t have...
Hi all I have seen a schematic drawing for a control panel recently where they (whoever drafted the drawings, designed the panel) show a RCD...
Hi all. Removed an ancient light fitting, replaced with a newer one, the light comes on but can't be turned off with the switch. It was working...
Hi all was having a problem with lights work one min not next took ceiling rose cover off to find a stray black wire only terminal free is the...
