Discuss Speaker system multi room in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
A
axel132132
Hi
Im looking at installing a multi-room speaker system with control in each room.
One room (Swimming area) Needs 2 Controls and 8 speakers
One room (Toilet) Needs 1 Control and 1 Speaker
One room (Toilet 2) Needs 1 Control and 1 Speaker
One room (Pool Room) Needs 1 Control and 4 Speakers
anyone know of any systems that can support this from ONE stereo system which will be in a Lobby.
Cheers
yep !
would highly recommend sonos too.
very good kit, loud and good sound quality, very easy to set up.
although for your 8 speaker room you may need multiple units to distribute the 8 speakers or wire in such a way to get around impedance problems :)
Reply to Speaker system multi room in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I have just removed a rather expensive CD system from a house. I did explain to the customer that I thought it was worth quite a bit, but they...
Hi I have a job where customer has two families one families lives upstairs and one family will live downstairs. As the property is going through...
Im in the proces of installing a meter room with 25 meters and riser. Allways i use communal area for cable route from each flats to meter room...
