Discuss splitting 1 phase of 3 phase supply query in the UK Electrical Forum area at ElectriciansForums.net
rwgs
Hi, I need to split a single phase from a 3 phase supply into 2 separate connections.
The 3 phases are currently being used by a shop and 2 flats above, with each using 1 phase. We have put a 3rd flat on top, however believe we can split one of the existing phases so the 3rd flat can share it (probably with the shop), rather than having a new connection installed. Is this correct?
Is this something an electrician can do, or do I need to get my local DNO to do this? The idea being then all the utility company have to do is fit a meter for the new connection.
Post up your rough location mate, one of us will be near you and will be able to come to take a look and give you proper advice
Reply to splitting 1 phase of 3 phase supply query in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone, I have been asked to pull in some new 3 phase supplies for 7 new welders which do not require a neutral connection. The client has...
Good morning, So I’m working on an existing 3 phase solar system and the customer wants a way to use the huge mass of exported solar on their...
hi guys / girls , any advice would be appreciated, So the situation is a domestic property has a 3 phase supply , from the service head we have 3...
Hi I have a question hoping I can get some help. I wanted to know if there is a 400V 3 phase supply (A/A/A) terminated on the primary side of a...
Good day to you. I need electrical drawings urgently and hopefully there is someone that can assist me. They are all for electrical trade test...
