J
Johnlondon
Hi all,
I imagine it's a simple answer......
I'm having fitted a new dual rcd cu to replace old catridge unit and currently, the garage feed is I'm told from a spur off the ring main. I'm told it's MI cablle joined somewhere under floor of the house to the garage.
All functions ok. garage load is at most at any time a striplight and maybe something like circular saw or bench sander.
Do I have to split it when the new cu is fitted (rather avoid that!) or can I leave it as is and perhaps have a small garage cu fitted when the main one is replaced?
Having an electrician to do it but just working out what to expect when the work is done.
Many thanks!
Many thanks!
