Discuss Spot the electrical crime in the UK Electrical Forum area at ElectriciansForums.net
Is it when he "pops a blank plate on that"?
He hasn't twisted the wires and stuck gaffa tape over them properly? :D :eek:
Cable twisted on the floor? Cables not clipped on the floor? Cable routed through the backbox? Not really safe isolation because the spur was off and not the MCB? The abortion with the clips and the towel radiator? Come on I need to know !!! :eek:
Much more fundamental than any of that!
The cores are gonna get spiked by the screw on the right hand side?
I must be honest I didn't even notice that the backbox isn't earthed.
There is an argument though that the backbox needn't be earthed if it has one fixed lug although in this case that's never going to happen since the blank plate has no earth connection. Personally I always stick in a fly lead just to be sure.
Well spotted.
[automerge]1568910676[/automerge]
Glad to see i'm not the only sad b*stard that watches these kind of videos on youtube.
I feel it helps you to expand your knowledge and sometimes see a better way of doing something.
have to say though that sometimes like here you see something you wished you hadn't :rolleyes:
ha - Now you've said it even I can see that.
So those need earthing regardless of whether they're just being used as a kinda junction box then?
there is an argument though that the backbox needn't be earthed if it has one fixed lug although in this case that's never going to happen since the blank plate has no earth connection.
well spotted.
I can follow that argument when say a socket face is attached, as the socket earth is connected to a metal bush that the screw sits in, thus bonding the screws and back box.
however this is not the case for most light switches and blank plates.
except grid switches.
Yeah Dan because if there was a fault in that box and it became live it wouldn't automatically disconnect the supply. Leaving the box live.
Once plastered around in many cases you may "get away with it" because the screw heads aren't large enough to be considered exposed conductive parts but the back box is and by the looks of it probably wont ever be filled around. Its just good practice and proper workmanship to earth the backbox.
[automerge]1568911130[/automerge]
Think along the lines of the absolute fundamentals.
Think about what we no longer term EEBAD...
I was even thinking about supplementary under the sink to be fair.
I can follow that argument when say a socket face is attached, as the socket earth is connected to a metal bush that the screw sits in, thus bonding earthing the screws and back box.
corrected that bit for you. bonding relates to extraneous parts. sorry to be pedantic. :D :D :D
I hate this.. its rough. I'm pretty sure there is stupid regulation that state as long as the surface area is less than a certain CSA it doesn't require earthing as long as it is RCD protected.
I'm going to try and find it now ?
don't think your going to find it,
best of luck.
Reply to Spot the electrical crime in the UK Electrical Forum area at ElectriciansForums.net
I have 16 ceiling spots to be replaced in a room being repurposed as a bathroom. Some will be over a shower, basin and bath hence need to be IP65...
If I click on the "Please help the forum out by replying to UNANSWERED THREADS by clicking here.", for the last couple of days it is infested with...
Hello I'm Crispin. Nice to meet you all. A landlord with an unfortunate tenant who has lost in the region of £1000 after a neighbour appears to...
Hello, Looking for DIY electrical advice. I have 7 x spots, and each are fitted with 1 x T&E connector block fitting [see photo]. In the past...
I have taken delivery of an undersink water heater. It is fitted with an RCD on the electrical supply cable which terminates with a euro-plug. I...
