- Reaction score
- 25
So I am going to fit a spot light using 1.5mm weatherproof flex with a 3amp switched fcu from a 32amp ring main. Just thought I would make sure This is correct before I start ?
Discuss Spotlight in the Electrical Forum area at ElectriciansForums.net
Thanks I think the light comes with 0.75 flex standard tbh.you could use 0.75 flex if it's on a 3A fuse. otherwise all good.
Reply to Spotlight in the Electrical Forum area at ElectriciansForums.net
