Discuss Spotlights tripping MCB when switched on in the Lighting Forum area at ElectriciansForums.net
DRM
Hello, my mate’s asked me to look at his spotlights in the kitchen because they were temperamental for a few months going off for hours at a time then coming back on and now they just trip the MCB as soon as switched on. They’re 12v spots.
They were on a dimmer switch so I changed that first to a standard switch but it still trips.
I assumed it was a transformer issue so I pulled a couple lights out until I found it and disconnected the mains from it keeping the live and neutral separated and then tried the switch, but it still tripped!
The cable feeding the tranny is a 2 core black sheath so I’m assuming it’s been wired to an existing ceiling rose or junction box.
The fault has to be between this and the switch but we can’t access them without a lot of messing about and because I’m not the best with spotlights anyway (can’t stand them) I was hoping someone might have some ideas? Am I right in thinking there is only one tranny? I’ll post some pics, cheers!
It's likely that there is a transformer for each light fitting based on the 65VA rating of that one. But without actually being on site and looking none of us could tell you for certain what is above that ceiling.
I would strongly recommend you get an electrician to sort this out as you are clearly guessing at what the fault is and potentially creating dangerous situations by doing so.
I think there is more than one transformer.The pic you have posted would feed 3 - 20 watt lamps or 1 - 50 watt lamp,so it depends on what wattage the lamps are as to how many transformers there are.
Ok cheers, the reason I thought there was one transformer is because All the lights were going off and sometime later coming back on, instead of it being localised to only certain lights
Reply to Spotlights tripping MCB when switched on in the Lighting Forum area at ElectriciansForums.net
Hey all, hoping someone can help with a particularly annoying problem! Have changed a load of LED downlights to the fixed bulb Centorio type (14W...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
Good evening, I have recently moved into a new home and I am having problems with the MCB/RCD tripping (Mem M6 Type 3 - 30mA). It intermittently...
I'm not sure what's going on with my kitchen light. I've replaced an old 28W CFL fitting with a new 4 x LED GU10 fitting (a cheap one from...
