Y
yarcyk
Hi.
I would like to know if I can connect socket to radial circuit to power diswasher and washing machine (double socket) with fused spur. I know that circuit should be fused 20A so if I use 13A fuse it will probably blow fuse if both working together, can 20A fused switch be used? (I don't think it can but want to know for sure), otherwise what is the best solution to have both appliances connected with fused spur switch above the worktop in the kitchen?
