Discuss Spur off a Spur, extra sockets? in the UK Electrical Forum area at ElectriciansForums.net
Guess that shuts them up.so out came the big book
Want to leave the current setup and add a new double socket and a new single and and swich fow dishwasher.Sorry if I'm being thick but not totally clear, are you saying you just want to change the existing high level single socket to a double now and leave the DP switch and single as arranged at the moment ?
Yes this is what I meant in my reply remove the short link between D.P. switch and single socket extend ring but as said you will need to confirm ring the assuming that you are burying the cable in wall also sockets used by ordinary persons RCD additional protection will be required.Hi,
Thinking about adding to the circuit now? (picture attached). In the photo the red wire that is being dicussed fell out.
Citcuit is RCD protected, I am a DIYer, I think it on the ring I can follow the cable under the floor to next plug?Yes this is what I meant in my reply remove the short link between D.P. switch and single socket extend ring but as said you will need to confirm ring the assuming that you are burying the cable in wall also sockets used by ordinary persons RCD additional protection will be required.
Reply to Spur off a Spur, extra sockets? in the UK Electrical Forum area at ElectriciansForums.net
