Discuss spur off spur legal? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
T
tommyaweek
Hi
I want to spur off a spur
The main socket is in bedroom which is spurred to hallway and I would like to spurbthat into cupboard for dishwasher and dryer that is going in there
The spurred socket in hallway is usuallybused for hoover
Also fuse box is in cupboard
Advice?
How would I do it or can I do it
Really appreciate advice
No mate, don't. If you're not a sparky, which from your question I'm guessing you're not, get one in to advise properly
If fuse board is in cupboard it would be very easy for an electrician to properly extend the existing ring main.
The appliances you are talking about are also fairly high current items.
Do it once, do it properly
Lol to all comments
Na I called electrician from yellow pages and he said you can but I thought you weren't allowed
I think he just wants extra money
No, you're not going to be able to do that. You can spur off a spur if the whole leg is fused, ie to 13A, but have any 2 of the 3 appliances on at the same time and you'll probably blow the fuse, which is bad design.
If the consumer unit is in the cupboard you're much better off getting the socket wired straight from the board.
Reply to spur off spur legal? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Grateful if someone could offer some advise, I'm struggling to find a definitive answer to this. I have a double socket, it was on the ring main...
DIY'er question: I have a singe switched fused spur above my kitchen counter, providing power to an undercounter fridge socket beneath it. The...
Hi I have a switched fuse spur where the cooker hood should plug in to… above the actual cooker. I was wondering if I could swap this out for a...
Hi, if getting back to the CU is not an option, instead of spurring off a socket via a Sfs putting the rating down to 13a. Could you spur off the...
Hi guys, newbie posting! Does the following sound ok... Existing circuit: SOCKET on a ring -> spur to SWITCHED 3A FCU -> SWITCH -> hardwired FAN...
