Discuss Square D rcd wont trip with my tester in the UK Electrical Forum area at ElectriciansForums.net
magnoliafan89
Hi guys wondering If anyone can shed some light either through knowledge or experience of the same problem.
I have a Megger MFT 1731. Whenever I come to square D type rcds my tester doesn't trip them. I try it on doing the manual settings for 1x and 5x and even the auto. Ramp tests won't either. I manually turn them off and and on a few times and test buttons use to make sure they haven't stuck or anything.
Yet when my colleague uses his rcd tester hes able to trip them.
No other type of rcd or robo gives me problems just this make.
Am I missing something or is it my tester?
Are you testing at the DB, or away from it? I have had problems with MEM RCBOs not tripping when tested at the DB but would when at a socket etc.
Testing both at the rcd and at a socket or light etc. No just i had a photo of that one spare but otherwise it's all sqaure d rcds
Its just odd that mine wont trip it yet when my colleague comes his can
have you tried a ramp test with your meter?
Reply to Square D rcd wont trip with my tester in the UK Electrical Forum area at ElectriciansForums.net
Called out to fault on RCD tripping maybe twice in a month for sometime. Did all the tests & found RCD was faulty, Refitted a new Rcd Type A which...
I get how they work and can kind of understand the reasoning, I remember the early "no-trip" RCD testers, D-LOG made one that saturated the RCD...
Hi all, There's 2 single fan ovens in the house my mother recently moved into. Posh elecronic AEG units. It's been sat empty for a year, so the...
Hello! I've been racking my brain this evening about some RCD selections. I've been doing some work for a solar installer, and they've asked me...
