- Reaction score
- 22
Discuss Squeezing the last Drop in the Electrical Engineering Chat area at ElectriciansForums.net
This is an “electronics” forum. I was hoping for an expert’s opinion, pro or con either way with an explanation why.I suggest that you build it,
test it and post the results.
best of luck.
This will be a very short thread if you continue like that.This is an “electronics” forum. I was hoping for an expert’s opinion, pro or con either way with an explanation why.
I am shocked to discover, no suck people here
Steady on, it did make me chuckle, i needed it after just lighting a log as too scared to put boiler onThis will be a very short thread if you continue like that.
Sorry, I don't have time, I'm too busy pumping air in to buckets at 20 fathoms.Perhaps someone could provide an exhaustive answer, if a suitable hourly rate can be agreed for their time.
I would like you to put your money and knowledge to this project.With fossil fuel energy on its way out, I have been trying to come up with a way to save the energy we now use. Here is what I came up with.
May the rock-throwing begin.
comments pro or con welcome
If you know why it will not work, then say it. I am a big boy, I can take it and then just move onrather than people tell you why it won’t work
I know that oil is finite, and we are using it all up. I am just liking for alternatives., you are obviously a person with deep commitment to your ideas and theory’s.
I do notif you haven’t got the ability to do it
Thanks, then post a design with specifications and I will gladly quote to build it for you.
So basically this project is going no where, you can’t do it and don’t seem interested in employing anyone to do it for you.If you know why it will not work, then say it. I am a big boy, I can take it and then just move on
I do not
Electric motors are not 100% efficient. Having said that, a 100hp motor puts out 100hp+a small amount of energy not consumed in its operation. It is that small amount that I was trying to capture.With fossil fuel energy on its way out, I have been trying to come up with a way to save the energy we now use. Here is what I came up with.
The losses you are trying to capture are lost in the form of heat and sound.Electric motors are not 100% efficient. Having said that, a 100hp motor puts out 100hp+a small amount of energy not consumed in its operation. It is that small amount that I was trying to capture.
Again, if you think it will work, put your money where your mouth is, make it and test it.Electric motors are not 100% efficient. Having said that, a 100hp motor puts out 100hp+a small amount of energy not consumed in its operation. It is that small amount that I was trying to capture.
Reply to Squeezing the last Drop in the Electrical Engineering Chat area at ElectriciansForums.net
