Discuss stairlift charger on minor works in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
B
bulby
Hi, my boss is telling me to install fuse spurs on a minor works which he says involves breaking into the ring main and fitting the spur at top of stairs. I cant see a problem ! when there is no accessible ring he is now telling me to stright to the DB and fit new cable in with ring main breaker and its an addition to a circuit so it can be done on a minor works, is this right ? i beg to differ but he's saying it fine.
Can anyone please advise
you would be adding a spur at the DB. not a new circuit, so MWC is correct.
Reply to stairlift charger on minor works in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
Evening all, I just wanted to see if electrical improvers/adult trainees with appropriate levels of experience and who hold testing...
In a property with two consumer units one for the ring main etc., and the other for the 1970s storage heaters (storage heater CU looks like it’s...
Morning all. I was chatting with another spark the other day and he’s telling me I’m making excessive work for myself by issuing minor works...
