Discuss Stairway movement sensor wiring in the Lighting Forum area at ElectriciansForums.net
Hello, I want to install movement sensors where i have my light switches on my staircase. At present i have a two way switches at both the top and bottom of the stairs.
Any advice will be very much appreciated
To add to the above, are you intending replace one of the switches with the sensor or add it to the circuit?
most sensors like this require a neutral to operate. It may be you don't have one at your switch positions.
Boston? forgive my geographical ignorance, but is that a UK Boston, or the Massachusets Boston?
Hi - as mentioned by @littlespark the motion detectors need to be powered (have L and N). This applies wherever they sit and so some new wiring is likely to be needed. One question will be - will you still need the light switches? (for manual over ride say)
Could use some ceiling PIRs, then you will have your Neutral.
Reply to Stairway movement sensor wiring in the Lighting Forum area at ElectriciansForums.net
Hi, Some advice would be appreciated… I have 4 downlights in the bathroom and want to add a motion sensor to turn on just one if everything is...
Hi all, I just found this forum last night and figured I would post my issue since I can't find much out there with a similar situation. My job...
Hi, I have two 3-way toggle switches by the opposite sides in my garage. Is it possible to replace both of them with motion sensors? Thank you. .grig
On either side of my front door is a motion sensor wall light - it looks like both lights operate from one light switch inside the house. The...
Hello everyone... There are a total of 4 cables entering the junction box at the top of the staircase. Two 12/2 cables are coming in through the...
