M
millymolly35
Hi Guys,
I need your help again, basically I have an electric oven and gas hob that are both run off standard wired plugs and plugged into an electric socket behind the oven, i think this bit is okay. Just above and slightly to the right of the hob I have a double gang socket, that when you take the front off it is wired up to red and black wires which I think is the old cooker circuit, is this compliant with regs? I have been told that the plug socket is too close too the hob by one electrician whilst another said it wasnt a major problem and would pass a periodical, my main concern however is the fact that its wired to the cooker circuit is this a problem ?? Thanks in anticipation
