Discuss Starbreaker MCBs in the Australia area at ElectriciansForums.net
W
wansbrough0
This is a really basic question. I have an old Crabtree Starbreaker c/u (dated 1992) that uses mcbs that slot in. Is there a recommended method to remove them as obviously I do not want to use unecessary force. The instructions tell how to intstal them but not to remove. Thanks, Paul
Reply to Starbreaker MCBs in the Australia area at ElectriciansForums.net
So that I can understand how the electrical energy that I consume is being used I want to fit one of these to my consumer unit (CU) -...
6K
Hi all New to this forum, looks like a hive of information. I'm wanting to upgrade my garage electrics - I'm not a qualified electrician, hence...
Done an EICR this week on a small flat, no issues other than the CU, E-line dual RCD, plastic, roughly 10 years old. MCBs didn't seem to sit right...
I know how I was taught to test a RCD, 6 tests in all two no go, two under 300 mS and 2 under 40 mS with no load. But thinking about it not so...
Last time I posted on forum it was on the thorny issue of over unity machines which alas got confused with perpetual motion -- and other supposed...
8K
