Discuss Storage Heater CU Replacements. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Spudnik
Just had a conversation with the tech's at Elecsa about replacing a storage heater CU and the 17th with RCD's and RCBO's etc.
Basically, you DO NOT need to provide RCD protection to each circuit individually.
An RCD main switch at 30mA is perfectly acceptable to cover all the circuits.
I would say what about discrimination ie one storage heater pops the sw ( the stat goes or the thermal cutout which can happen quite often with old ones ) and you lose all your heaters in one go NO heating in entire house/flat .Does not sound right to me if anything needs to be on separate rcbo's then its your heating for the house.
I understand what you are saying Scott, but the only reason we have to use RCBO's or dual RCD boards is for circuit separation in the event of a fault, (and the 50mm rule) taking out an RCD with, say, all the lighting on it, which would then increase the risks of injury going to reset the tripped RCD.
Safety wise, there is no risk if the heating has tripped, just an inconvenience.
No different if your boiler breaks down. Its not unsafe, it just doesnt work.
"Safety wise there is no risk ".Not unless Granny freezes to death in the night because all her heating went out .
You would have to be unlucky for that to happen but ?
Regs are in the van .But if you change the board then it must comply with 17th
From my experience storage heaters can be a pain in the arse.I used to work for council maintenance and in the cold months we were always going round to reset the thermal cut out.
Its your call and if Elecsa say its cool then its cool
end of the day it will be you going back if any faults arise (alright before you changed the board syndrome)
"What would you do if it was your house' is always a good yardstick
Im with you on all of that.
However, the Cu would be 17th as all of the circuits would be protected via the RCD main switch.
Again, with granny, no different if the boiler packed up!:)
REG 314 "DIVISION OF INSTALLATION"
(1)AVOID HAZARDS AND MINIMIZE INCONVENIENCE IN THE EVENT OF A FAULT
How are you complying with this reg as stated inBs7671
Hope its warm where you live !
Ps don't show your Granny this thread she might get offended
Reply to Storage Heater CU Replacements. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi Guys, Had a call out today about an odd issue with a newish Creda DT storage heater. Basically.. Storage heaters were installed in one flat...
In a property with two consumer units one for the ring main etc., and the other for the 1970s storage heaters (storage heater CU looks like it’s...
Been round to a house to quote to replace some storage heaters for new panel heaters and came across a strange (to me at least) way of wiring the...
4K
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
