Discuss Straned Cable in the Industrial Electricians' Talk area at ElectriciansForums.net
O
ONIT
Good Day All, Any Throuhts On Straned 2.5 Cable On Ring, Passes All Tests Feeding 12 Sockets
How Long Is The Life Span, Came Across It Today Also How Many Have Come Across One Ring Feeding Up Stairs Sockets/down Stairs Sockets
Cheers
Do you mean old .7029 ?
As for the upstairs/downstairs ring, dont think there are any rules against it other than the floor area not exeeding 100m square, however some of the other chaps are more up on regs than me and may know otherwise !
I pass it on my certs (if it tests out ok) but my boss advises me to suggest that a rewire is necessary on the certs.
Cheers If Test Ok, Saying Rewire Its Just A Way Of Making Money, Thats Ok If You Dont Know The Customer And Your Trying To Save Them Cost
Reply to Straned Cable in the Industrial Electricians' Talk area at ElectriciansForums.net
Was having a poke around the old man's house today. Anyway. DB is under stairs (18th ed following a recent extension. Not done by me but it's...
Hi all, I'm planning to remove a stud wall seperating my dining room and kitchen. On the dining room side of the stud wall, there is a double...
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
