danesol
Right, I've been struggling with proper monitoring now for sometime, but seemed to have partly solved this now ...... however, it isnt exactly right on a conditional basis - can you experts point me in the right direction why this is happening;
OK, the tails are split straight after the DNO meter into a Henley Block, where the 6mm AC SWC cable from the PV also connect to, naturally the CU connects to this using the existing but previous cut tails. Currently nothing else runs off the SWC cable/ 2nd CU of the PV system.
Now here is the interesting bit - when I use a CT claw around the "+tail" to the CU so that I can monitor all useage of electric in the property ( not really interested in the net reading as the DNO reading provides this ) its not fully correct, which is odd as both the DNO and the PV are technically behind this in the wiring scheme and therefore in my mind should provide the net value of electric flowing into the property .........
I have now acquired an additional CT claw, which I have placed around the DNO "+tail" to the Henley block - the two addup to exactly what I am using within the property as long as the PV is working, if the PV is not on, naturally the figure is nearly dble what it should be - lol
Just to elaborate on the two figures equalling - I am assuming partially this, as the old DNO meter wheel has stopped, the PV reads xx and the Envir monitor also reads xx - therefore I am assuming from that that im using exactly what the PV is generating and importing no electric whatsover.......
I just cant workout why I have this situation unless within the property there is an underlining wiring issue ????
Doesnt make sense in someways - any comments ?
