I have an installation that I maintain and the DNO have recently changed their pole transformer. Since this change I have been unable to do earth loop tests. The supply comes from a HV to LV transformer and there is a HV earth rod right next to the neutral/earth rod for the HV to LV transformer.
The installation is a TT system with one earth rod. For some reason I get 186V L-E and 66V N-E and 252V L-N at the cut out fuse when the fuse and the neutral are removed.
Could it be stray voltage from the HV system?
And why would this not give me an earth loop reading on my tester?
Thanks in advance
Thanks in advance
