Discharged
I might have asked about cable stripping and preparing on earlier time - sorry if a repeat.
I need to save time in pulling off the outer sheath of plastic around cables. Does anyone know of some wonder tool that could do this in a jiffy? atm I'm scoring a line with Stanley and not always doing to the right depth and often the circle does not match up!
What I had in mind was a sort of semi-circle affair where you place the cable at the length where you want to cut, close the top cutter on that, maybe rotate the cable, or the tool (like a copper pipe cutter), and pull the thing toward you so leaving the bit you want, all neat and ready for further work.
Am I dreaming of such a tool?
Thanks.
Thanks.
