Discuss Stuck on light fixture! Help! in the DIY Electrical Advice area at ElectriciansForums.net
Hi everyone, I'm new here and I know little about electricals apart from wiring a plug! It's something I've wanted to always learn even just the basics so I am grateful for any advice.
I've had a 3 bulb ceiling light fixture for a few weeks now. I cannot for the life of me figure it out. It's old wiring so its the black and blue and a striped earth. The new fixture is the modern blue and brown wires.
There was also an existing cable there in a grey cable. It's thicker than the others. There's 2 light switches. One at the bottom of stairs and one at the top of the stairs. I just want all 3 lights to come on and off with either switch as right now I can only get one to light and the switches don't respond! :D
I got no idea how to wire it into the little block that came with it correctly lol!
Yes it will be difficult to give advice for you correctly connect it in a safe way. Those fittings are notoriously difficult to install in a compliant manner, get an electrician out shouldn't be a huge outlay.
Okay mate, first things first - it looks like what you may have there is a borrowed neutral. My best advice is isolate your board by the main switch and get a spark out. (Seriously, borrowed neutrals have killed unsuspecting folks)
Why would it be a borrowed neutral? Could be just a looped neutral between roses. I know they are of a different cable type but that does not say it is borrowed. But indeed it does require identifying. As it could well be any form of conductor, without testing a picture will not tell.
I didn't say it was, I said it may be -because it may be. Lots of borrowed neutrals done in singles means cause for concern.
The advice you've received from @westward10 and @hightower is good. If you're near Newport or Cardiff, drop me a PM with your number and I'll give you a call to arrange a visit and if you're not let us know where you are as another member may be able to help.
Lots of all sorts done in singles my friend. But your are correct saying it should be established what it is doing. Not really a DIY jobbie though!
My Question, did you take the light fitting down?, where was the single conductor connected too.? As said could be loop feed N L, shared N even E, need to get an Electrician to establish.
Reply to Stuck on light fixture! Help! in the DIY Electrical Advice area at ElectriciansForums.net
Made the massive mistake of not taking a photo beforehand and am now stuck with a light fixture that I'm not sure how to wire. I'd removed an old...
Hello, my house was built in the 1950s and every time I look behind a wall plate the wiring isn’t how it’s shown in any DIY book I’ve read. I’m...
I installed these round light fixtures in my office 23 years ago. After a few years the circular flourescent tubes went out and I replaced them...
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
