I have been living in this house for five years. From time to time, the sub main breaker (bottom-right in pic1, the RCCB breaker that is tripped in the photo) for the ground floor would be tripped. This happens during the raining season (June to October). In the dry season, there is no problem. I have identified five breakers that are at fault. When I turned them off, the sub main breaker would be tripped at most once a week. I could live with that. This season is particularly bad. More sub sub breakers are tripping the sub main breaker. This morning, the sub main breaker was tripped at around 1 am and about every 20 - 30 minutes after that. There had been two times when I flipped down all the sub sub breakers with red label (the bottom two rows) but still couldn't flip up the sub main breaker. I then played with the the breakers with yellow label and found they could also trip the sub main breaker. At that moment, I realised they were also controlled by the sub main breaker.
Thinking the sub main breaker was no good anymore (about 20 years old), I purchased a new one (the one in pic1) the first thing in the morning. It did not help at all. I have to flip down more than 20 breakers to keep the MCCB up. Now, most of the circuits are off. There is basically no power on the ground floor.
I called up an electrician friend and told him the situation. The first thing he said was "That's impossible." I said: "I thought so too but it's happening."
Any theory, however remote it might be, that could possibly explain this situation?
