Discuss Sub main Off a Sub main???? in the UK Electrical Forum area at ElectriciansForums.net
i have been asked to run power to a timberframe outbuilding (6mtr x 10mtr).
there is a garage cu which is a submain of the main cu, which would be easier and more practical to run the power from.
i havent actually been to the site yet, but assuming suitable CSA feed to the garage cu, can i then feed off from the garage cu to another cu in the outbuilding?
You might find it difficult to co-ordinate the ratings of MCBs if any of the new final circuits is anything more than 6A.
I don't think that it's too critical although your correct if it was any other type of installation ie commercial there would be more of a risk/inconvenience.
Hi - perhaps service split before the garage CU to avoid adding to co-ordination issues etc. I’m seeing SWA entering garage and having some half baked connection to that CU (oh so many of these). Fix that with an adjacent box and add a new SWA ongoing to the next shed, perhaps.
Reply to Sub main Off a Sub main???? in the UK Electrical Forum area at ElectriciansForums.net
I wondered if it is OK to have 2 x Main Switches in the same consumer unit. One feeding the RCBOs in the House and one feeding the CU in a garage...
Hi, if getting back to the CU is not an option, instead of spurring off a socket via a Sfs putting the rating down to 13a. Could you spur off the...
Now that SPD's must be fitted regardless, how does this stand from a sub-main perspective? Went to look at a job and they want a supply to a pre...
Hi all. I have been asked to take over a job an electrician has started, and has moved abroad. The house is a big mansion, with a 3PH supply...
4K
Hi fellow sparks, I've just started out on my own so I'm spending a lot of my time trying to find out the correct way of doing things of...
