Discuss Sub panel.wiring question in the UK Electrical Forum area at ElectriciansForums.net
Terp393
Hello I am wiring up a 100amp sub panel in my shop the run is about 230 feet so I was advised by the supply house to use 1/0 aluminum, I was told that the breakers at the main panel at the house would not accept the 1/0 aluminum, what would be the proper way to connect the wires I have seen like step down pins that could be used but not 100% sure if they would pass inspection thanks
If you are referring to 100 amps for the panel I would use four # 3 copper wires and install a main lug only sub panel. The wire will cost a little bit more but it’s half the size of copper. Remember that all buildings or shop in your case has to be GFCI protected
Reply to Sub panel.wiring question in the UK Electrical Forum area at ElectriciansForums.net
I am adding a 60 AMP subpanel for a detached garage/workshop with a 200 foot underground conduit run from the main panel to the sub panel...
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
Hi, I am burying wire from the outside meter panel to the new 100amp sub panel inside a garage. The run is 20' long. Is 2-2-2 Aluminum URD Cable...
At long last my wife is getting her new kitchen and the contractor will be running 10 or so new circuits from a new sub panel. The sub panel...
I’m planning on putting in a small (10x10) detached shed for garden storage plus a freezer for meat storage, an in-wall AC unit (for temperature...
