Discuss Suggested cable for large cooker in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
K
ktech
Hi,
Anybody got a suggestion for the cable type to run from an isolator to industrial cooker?
Situation is:
63A 3 Pole MCB wired to 4 Pole isolator via 10mm SWA (XLPE). Cable needed is to run from isolator to fixed cooker.
It's been suggested to use 16mm H07, does that sound ok?
Thanks.
Looking at it isn't 10mm SY rated at 47amps for 3 phase? So I think I would need 16mm (63amps)
Reply to Suggested cable for large cooker in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi! DIYer here. I have an MCB running to a cooker isolator switch. The RCD connected to this set of MCBs is tripping and isolating the cooker MCB...
I'm obviously still new and learning about what I can and cannot do, but essentially I want to install an EVSE at my own house for an electric...
Hi, just looking for advice. Ive been to look at a Fire alarm install job. While checking where i will take my supply from. 3 phase sub board, i...
